Water leak! Help!
Coach_E
Water leak! Help!
Post by Coach_E »
Hi All, I recently purchased a 71 ranger XLT long bed. There is a water leak that would like some help on, hopefully someone can tell me with these clues;
-Water leaks out of the water pump area( not sure where, it was too dark to tell )
-Here is the catch, it starts dripping when I fill up the radiator. This is when the truck has not even been turned on. I thought when the water pump was bad it would leak when the truck was on?
Any ideas?
Thanks in advance!
TNIceWolf
Re: Water leak! Help!
Post by TNIceWolf »
Sounds like it's coming through the "weep" hole in the water pump. Probably the water pump shaft seal gone.
Presently in the stable
1969 Ford F-350 DRW
What engine...
Ideas:
Gasket on back of pump.
Pump to block gasket.
Water pump bolts go into water jacket but do not have sealer on them.
Coach_E
Post by Coach_E »
Thank you everyone for the quick responses. I will get more info on the engine as I do NOT know what motor it has. Anyone know how I can check? I know its a V8 by looking at the dizzy. Exact engine, I have no clue since there is no stickers to be seen and the previous owner did not know.
From everyone's posts, it seems like it's just a seal? I hope so! I was worried the actually motor had a leak. Is it still possible for the motor to leak with the motor not being turned on?
Thanks again!
Have a look here:
http://www.fordification.com/tech/technical-index.htm
Particularly:
http://www.fordification.com/tech/VIN71.htm
and
http://www.fordification.com/tech/engineID-V8.htm
It is possible to damage a block from disuse if its in a cold climate without proper antifreeze... but normally seals and gaskets are what go from sitting...
could be a leaky heater hose too.
Coach_E
Post by Coach_E »
DuckRyder wrote:Have a look here:
Particularly:
and
Thanks for the links! :thup:
If you have a damaged block, will the water just drip out of it if you put water in the engine without starting? It doesn't need any pressure? I'm still hoping its a seal or gasket!
Coach_E
Post by Coach_E »
fordman wrote:could be a leaky heater hose too.
I hope its something easy like a hose! Thanks for your input.
