remove fuel tank with cab and bed on?????
customcamper
Post by customcamper »
Can you remove th fuel tank in between the frame rails with the cab and bed on from under the truck??? The bed is loose so I can move it back a little but how hard is it to remove with the cab on???
Re: remove fuel tank with cab and bed on?????
its just unbolts from underneath.
1971ford
Post by 1971ford »
Not hard.
Pull the skid plate off, disconnected fuel line, wires, and filler neck, pull straps, don't be under it.
-Ryan
