MOtorcraft 2150 help, and a exaughst question
OldRedFord
Post by OldRedFord »
Someone I know recently bought a 1970 F100, with a 302. It has a Motorcraft 2150 carb. Im looking for tips for carb tuning, and vacuum line hook ups to the carb.
Now for the exhaust. There is a leak on the passenger side between the exhaust pipe and manifold. Is there supposed to be a gasket there?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: MOtorcraft 2150 help, and a exaughst question
yes the exhaust has a doughtnut that goes between the pipe and the manifold. felpro part number 60987 well that is the one fo ran fe. it is the all metal type.
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
These carb rebuild sheets have all the needed info on getting them set up and adjusted:
http://www.fordification.com/library/ma ... temId=5574
http://www.fordification.com/library/ma ... temId=5592
OldRedFord
Thanks! Forgot about that section. :lol:
Tim
derek7871
Post by derek7871 »
When you install the new donut gasket, make sure you tighten both side evenly. If not, you'll be replacing it again soon. Ask me how i know....
Cooter
