Camper Special AUX Tank Removal
I'm working on cutting the bedsides off of my 72 CS and I was wondering how do I remove the aux tank. I took the 2 straps off and the skid plate and it didn't seem to want to go anywhere. Is the something I'm missing?? because using oxy-fuel near that old tank just makes me nervous even though it sat for years witout a cap on it. But any help would be very nice!!
60 Mercury Comet
65 Ford Econoline
77 Ford F250 "lowboy" 4x4
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
- kaptnkaos
Re: Camper Special AUX Tank Removal
Hey FordTruck
Check the fuel filler neck... on a '71 it runs between the bed and the frame, with that in place, it will hardly budge. Other than that, just keep chasin' bolts. There is a support the goes down the center... If I remember right, the straps hook to that.
Does your truck have the passenger side aux tank ???
I am wondering if the driver side tank could be flipped some how and used on the p. side.
KaptnKA
S
KaptnKA
2 straps 1 fuel line 1 filler neck 1 gauge wire and 1 ground wire. why dont you just unbolt that stuff. dont torch up stuff soembody can use.
I'm not I'm torching off the bed sides to make a flatbed and I don't want to be cutting above that tank and I wanted to clean it out. My plan after I get the flatbed made is to do away with the in cab tank and use the aux tank as the olny gas tank.fordman wrote:2 straps 1 fuel line 1 filler neck 1 gauge wire and 1 ground wire. why dont you just unbolt that stuff. dont torch up stuff soembody can use.
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
60 Mercury Comet
65 Ford Econoline
09 Harley Xl1200c
