Carb Issues!
zentar
Carb Issues!
Post by zentar »
Ive got a 1972 with a 360 and 2 bbl carb that I think is stock.Iam sure its been rebuilt before. It kinda hesitates when you first take off if you try to take off very fast and when its warm it is a little hard to start.Think its loading up cause it smokes some when it finally starts. Any suggestions from the carb guys because I am not a carb person.
No Excuses-Make it happen
towtruckerfour
Re: Carb Issues!
Post by towtruckerfour »
If it is black smoke you see when it starts, it might be running rich. Try adjusting the mixture screws. I've heard one and a half to two turns out is good.
Troy
Why is it that the trucks are always the best running vehicles in the family?
Ford means "found on road daily"
70 F100 Custom-352 w/68 Highboy 4x4 frame. My play/project truck
70 F250 Explorer-390/C6 auto. My work truck
04 Mitsubishi montero-family car
Re: Carb Issues!
the hesitation is the acelorator pump onthe carb. what color smoke is it?
V Majestyk
Re: Carb Issues!
Post by V Majestyk »
A blown power valve will also cause both problems. It lurks under a square,4-screw,cover on the underside of the carb below the floatbowl. SOME parts stores will let you get just the valve without having to buy a whole carb kit.
Don't need re-stored,can,t wear the d*mn thing out !
zentar
Re: Carb Issues!
Post by zentar »
Black Smoke. I know there is a gas tank behind the seat but you sure can smell it loading up.
Re: Carb Issues!
loading up too much unburnt fuel with the black smoke. the most experience i have had is to tell you to check the float and needle. to make sure they are working properly.
Sam I Am
Re: Carb Issues!
Post by Sam I Am »
Sounds like the choke is stuck closed.
68FORDJBM
Re: Carb Issues!
Post by 68FORDJBM »
Hi all. I'm having the same problem on the same year and engin - 360 dbl brl. Starts fine when cold but is difficult to start when cold and blows black smoke, smells rich when it finally starts. My carb is a new rebuilt carb. Was the final analysis the fule mixture running rich and did making the above mentioned adjustmenst fix the problem.
Thanks.
