390 cam removal question
hey yall...im doing a block up rebuild with the motor still in the truck...390 in my 69 f100...i was wondering if the cam will come all the way out with the radiator still in the truck or will it stop it short of coming out?? do i need to remove my radiator?
- SteveC
Re: 390 cam removal question
you will probally have to remove the radiator im pretty sure you will lack a few inches to be able to pull it out.
But if im wrong some one will correct me
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
1967 f-100 4x4
- convincor
figure the cam is as long as the block.
measure the block, and measure the space between the block and the radiator. You'll have the answer.
"Still Plays With Trucks"
Which is that the raditor has to come out.convincor wrote:You'll have the answer.
- convincor
right.
I just checked the dummy block and front radiator support I have mounted to the frame and found the cam will stick through the radiator support about 1 inch before the cam comes completely out of the block.
Bob
Bob
yes i had to remove my radiator to get mine out a few years ago.
