FE Oil-change tricks
- Supermike
Ok, so clearly on a 2WD FE, the oil drains all over the crossmember when changing your oil. Annoying. But short of changing the pan (which I'm not able or inclined to do right now), I'm curious if anyone has any "tried and true" tricks to channel the oil away from the crossmember?
I've seen it mentioned to fabricate something from steel (which I have no tools to do), and have also seen mentioned using aluminum foil or bending the "thick" aluminum from a turkey roasing pan. I've also seen this little doohickey referenced, but don't know of anyone using it (is there even room for installing it?).
So anyone have any "tricks" up their sleeve to make this a cleaner process?
Former owner of a '67 F100 Camper Special
Current owner of a 2022 Ford Bronco Wildtrak
- kaptnkaos
re: FE Oil-change tricks
Hey Supermike,
Keith fabbed up a metal tray that sits on the cross member that funnels the oil over the cross member down into an oil catcher.
It's pretty cool. He posted a pic of it in an earlier thread.
I can tell something that does not work too good...
I tried putting a piece of plastic sheeting over the cross member.
It sorta worked for a minute or two...
Then, it fell off and got nasty dirty oil all over the floor, all over me and everything else before I go it cleaned up.
About half the oil ended up on the cross member anyway...
KaptnKA
S
KaptnKA
- Redcap
I'm fortunate enough to have a gravel floor in my barn. The place where I do oil changes is extremely well-packed, due partially to repeated oil saturations.
- Supermike
Re: re: FE Oil-change tricks
Cool! I'll search for it, but you have a link? I'd like to see that...kaptnkaos wrote:Hey Supermike,
Also, know anyone that wants to make/sell some of them?
- kaptnkaos
Hey Mike,
No, I don't remember which tread it was in...
Someone else was askin' the same question and Keith posted it as a reply...
You might send him a PM. I'm sure he wouldn't mind...
KaptnKA
S
KaptnKA
Just use a peice of carboard! Quick and easy!
Steve
Steve
Chevrolet
1969 F100 4X4 Highboy 390 3sp
1969 F100 SWB 2wd Auto 351w
1972 F100 Ranger XLT 302 Auto
http://mrsnicks.blogspot.com
Sorry about the poor pic. Used the phone to take it.
This is a quick thing I made out of a piece of galv metal I had laying around. I left a lip on the left to fit under the oil pan. Tuck it under, undo the drain plug and it funnels right down the tube to the catch pan. Quick. Easy. Best of all in my price range. Free
- Supermike
Wish I could weld too, but you'd be surprised what you can make out of a rusted out rabbit cage and a pair of tin snips!
- ezernut9mm
don't use any of those contraptions. you don't want your cross member to rust do you?
. it does kinda suck though. i don't know what the ford engineers were thinking with this design.
