rearends
fourtss
rearends
Post by fourtss »
:cry: OKAY fellas, need some input so get on your thinkin caps, what would be the better rearend to use with an automatic (c6) the ford 10 bolt 3.25 with 5bolt lugnut or the dana 60 4.10 with 8 lugnuts??????? :cry: p.s. going behind a 360 with mild manner cam headers and shiftkit in tranny.
tom
2003 ford escape
1997 dodge 1500 4wd 5speed, 1963 Cheby Corvair,
FORDification
Site & Forum Admin
Site & Forum Admin
re: rearends
Post by FORDification »
Whichever one matches your front bolt pattern. ;) Even though it's a truck, you don't want to have to carry around a separate spare each for the front and the back.
The 3.25 gears in the Ford will also really help out with gas mileage by keeping your engine RPMs down out on the highway. That's a good compromise between true "highway gears" and the stump-pulling gears of the Dana 60.
pat67shorty
Post by pat67shorty »
What is the intended use of the truck? Dragstrip performance? Daily driver where maximum fuel economy is needed?
'67 SWB, 1970 car 390, Edelbrock Streetmaster intake, MSD 6AL, 780 Holley, Hedman headers, 2.5 duals, 3.54 D44 L/S, C6.
390Nut
re: rearends
Post by 390Nut »
If you've got an F100 2wd, stick with the 9" (10 bolt is a ch**y term/axle :off: )
I swapped from 3.25's to 3.50's in the rear axle, and mileage went from 12 to 10, just like that. Pretty close to swapping back, as I've noticed that even being relatively easy on the pedal it tries to get slippery in the back end when I take off around corners, from a stop. Could be due to the low gear in the tranny (4 speed) so an auto might be different, though.
`69 F100 390 4spd driver
Pipes71 did once say, "bumps and bikes.. what a great combo!" :thup:
