Found Rubber debri under valve covers!!
BobbyFord
Re: Found Rubber debri under valve covers!!
Post by BobbyFord »
Sand the dist. housing at the o-ring (with the o-ring removed) and the dist. hole in the intake with crocus cloth. That "metal" o-ring used to be rubber. Chop it off and replace it with the one that came in the gasket set.
Try not to get any sand debris into the engine....you might wear out the main bearings :D
70_F100
Post by 70_F100 »
BobbyFord wrote: Try not to get any sand debris into the engine....you might wear out the main bearings :D
Man, wouldn't that be a shame!!! :eek:
But with the precision fit of those bearings, even a speck of dust might destroy them!!! (Especially at high RPM's, say, 600 or so...) :doh: :doh:
1971ford
Post by 1971ford »
:lol: :lol: :lol:
Engine should be in tomorrow :D Wait... I've said that 3 times now
-Ryan
1971ford
Post by 1971ford »
TO update this thread, since this thread is basically the 360 "build" and installation thread.
This thread shows installation: http://fordification.com/forum/viewtopi ... =3&t=46780
It is sitting where it should now and is half way bolted to the tranny. I need to pop the driveshafts in, hook some linkage up, some wiring, and it might even fire in a couple days...
That's when the countdown to destruction starts lol I wish i knew how many miles this thing had. Might be a record lol
-Ryan
Fordnatic
Post by Fordnatic »
To properly install the intake manifold you should start the bolts (leave them loose) and then install the distributor. There is quite a bit of play in the manifold, and the distributor should be what aligns it. So fully install the distributor and get it so it goes in and out easily before torquing the intake bolts. This is most likely why it's hard to get the distributor in and out. Other than that problem it probably will still work, although it is putting some side stress on the distributor and may cause wear in the bushings.
70F100: 410 Merc with tri-power, close ratio toploader, 4.56 detroit locker 9"
68F100 4x4: 390, 4 spd/NP 205, Rancho 4" urethane susp, 35x12.50 All Terrain T/A's
55F100
01F150 Daily Driver: TP tunes, AF1 intake, elec fans, Magnaflow exh, underdrive pulleys, Centerlines
1971ford
Post by 1971ford »
Oh no, bearing wear! I'd hate to wear my bearings lol
But really thanks for the tip, i didn't think about that. It's all torqued to spec now so i would have to loosen it back up.
Oh and i found a set of new (5) FE main bearings for $40 on craigslist. This guy has tons of similar parts. I might pick them up to put in this engine in the future.
-Ryan
