Amazing how fast the bumpsides are dissapearing from pick-n-pull type yards
Re: Amazing how fast the bumpsides are dissapearing from pick-n-pull type yards
When i got my bump side about 4 yrs ago it was in pretty good shape but some things still needed worked on. I started scouring junk yards all around the area and there was nothing to be found. The yards i talked to said all those old trucks have been gone for awhile. It does really suck when your trying to fix something or rebuild something the only thing you can do is get new or rebuilt parts which is not cheap or go to CL which is another crapshoot!
- Jacksdad
Went to the wrecking yards this morning with my son and found three bumps.
I've been on the look out for small block motor mounts - but not this kind...
- Jacksdad
I'm surprised nobody's noticed that Pontiac motor yet...
- Manny
now that was a strange swap. why the heck a GM especially a pontiac.
The Junk that hangs around
1974 Bronco 302 3 speed
1984 bronco 302 c6 35's
1994 F350 7.3 5spd dually.
- Jacksdad
Ain't that the truth - a '70 2bbl 350 or 400 according to the casting numbersManny wrote:now that was a strange swap. why the heck a GM especially a pontiac.
- Manny
I might get a 455 4 bbl that somebody had laying around. maybe a 500 caddy but a garbage smogger pontiac.. somebodies brain was frazzled..Jacksdad wrote:Ain't that the truth - a '70 2bbl 350 or 400 according to the casting numbersManny wrote:now that was a strange swap. why the heck a GM especially a pontiac.
- Jacksdad
Yep - a few years back, I had a Buick 445 Wildcat motor going spare that nearly ended up in a few non-GM projects. But a 255hp small block?
- Manny
225 on a good day
of course its the same power as a 360....
- Jacksdad
...on a good day
And at least an FE bolts in. The conversion motor mounts were nicely made, but that's a lot of trouble to go to.
- 67mann
- Manny
My friend Ron in Maryland suffers the same way. The dents are about all that's left. The bumps are all but gone.67mann wrote:Living in NY....it's pretty common not to find a worth while Bump (if any)in a yard.Most have rotted right into the farmer's field where they were parked
My buddies dad owns a junk yard and he lets me know when one comes in but,
they leave a lot to be desired
The yard by me never had bumps the past few years I've been going. They had some dents but in the last few months they are down to 2 dents that are junk. I now need a tailgate but might be having to build one.
Kyle
Kyle
