Gas smell in the cab
socalcraigster
Re: Gas smell in the cab
Post by socalcraigster »
No smoking or farting in the cab until you fix the problem :yip: :yip:
1967 Flareside Shortbed Crew
1969 390 Ranger Long Bed
socalcraigster
I just noticed mine is doing the same thing.
But I just filled the tank with gas for the first time since I got it.
knightfire83
Post by knightfire83 »
Mine has always leaked at the cap, no matter what cap is on there. Leaks down the filler tube, past the "new" rubber grommet and down in the cab corner area. This is especially true if the tank is full and you go around a corner quickly. I just keep that tank 3/4 full when I fill it up, problem solved.
Also some fuel tank selector valves will leak just enough from the top of the valve to dampen the area around it and give you the smell.
:2cents:
1970 Ford F250 4x4 ~ Sold.
