240 to 360 swap
FORDification
Site & Forum Admin
Site & Forum Admin
Re: 240 to 360 swap
Post by FORDification »
The frame and crossmember will be drilled for the perches that support every engine that was available when the frame was manufactured. Since both the I6 and the FE were available when your truck was manufactured, all necessary mounting holes will be in place. Yes, you will have to move them to a different set of holes, but all holes are already there for you. No drilling required whatsoever. Whoever told you that you'd have to drill holes anywhere to mount an I6/FE perch is wrong.
The only time you'll have to drill new holes is when mounting a small-block with the correct small-block perches into a early-'69 and earlier frame. Since the 302 wasn't available until mid-'69, frames that were manufactured prior to that are not drilled for it, though all frames manufactured since mid-'69 do have the correct small-block perch mounting holes.
Hope that clears things up.
fordboy69
Re: 240 to 360 swap
Post by fordboy69 »
So my 360 will bolt in perfectly on the I6 mounts, and the I6 mounts are identical to the 360 mounts and they use the same mounting holes. Is that right?
-1969 F100 360FE
-1970 F250 (Parts Truck)
FORDification
Site & Forum Admin
Site & Forum Admin
Re: 240 to 360 swap
fordboy69 wrote:So my 360 will bolt in perfectly on the I6 mounts, and the I6 mounts are identical to the 360 mounts...
Yes...they're the exact same piece. Same part number.
fordboy69 wrote:...and they use the same mounting holes. Is that right?
No! You WILL have to move them to a different set of pre-existing holes.
Dragon
Re: 240 to 360 swap
Post by Dragon »
Go to Fordification.com technical and scroll down to perches.
fomocoguy
Re: 240 to 360 swap
Post by fomocoguy »
Good information for sure. Thanks guys! :thup:
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
fordboy69
Re: 240 to 360 swap
Post by fordboy69 »
So when I put in my 360 I'll use my 360 mounts and put them in a different set of pre-existing holes. It doesn't say anything about different holes for different mounts in the tech section.
-1969 F100 360FE
Re: 240 to 360 swap
sure it does. its one of the first few lines. the fe perches sit in the rear set of holes.
fordboy69
Re: 240 to 360 swap
Post by fordboy69 »
Ahh so use my 360FE perches and put the perches in the rear set of holes and drop er in.
-1969 F100 360FE
Re: 240 to 360 swap
yes if you have a saginaw power steering box use the perches to match the box. if nto just use the l6/fe perches that you have.
