Does anyone have a link or line on a new replacement FE engine oil pan?
I have a 1969 F-100, and I'm building a 390 (stroker) for it.
Are the oil pans for a truck front, or rear sump? I currently have a tired 428 in the truck, and it has a front sump pan.
FE Oil Pans?
FE Oil Pans?
1969 F100 Ranger LWB 2WD, PS, PB, 428/C6, 3.50 to 1 gears, 31 spline chromoly axles with a Yukon Grizzly Locker.
Re: FE Oil Pans?
Cars and 2wd use a front sump,
4X4 use a rear sump unless you have enough lift to clear the front axle.
drain plug location can be a consideration.
Re: FE Oil Pans?
NPD (National Parts Depot) has one for $141.50 Oil pan repro C7AZ-6675-A for 1967-1976 Ford Trucks with a 352, 360 or 390 FE engine, for 2 wheel drive truck. https://www.npdlink.com/1948-1979-ford-truck Go to the engine section, then oil pan.
Regards
Regards
Re: FE Oil Pans?
Thank you for the information!
