Cam Bearings
R.Smith
Re: Cam Bearings
Post by R.Smith »
"Trying to remove and replace them in the vehicle can open up a whole new can of worms."
Well, in that case I'd just say screw the truck, grab the worms and go fishin!
I doubt I'll replace them unless they are truely worn out though.
cdeal28078
Re: Cam Bearings
Post by cdeal28078 »
During a full rebuild they get replaced mainly because the block gets hot tanked and that would not do the bearings any good. and a rebuild means replacing all bearings of course. lol
I wouldn't mess with them just during a cam change unless you knew there was a problem. I know some shops use a long bearing press like a long rod with a fitting on the end for different sizes. I DON"T know if the bearings are line hones in any way to make sure they are lined up right though. Bet somebody here does
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
