On my son's '67 F100 (352 w/auto) if you install a radiator cap and build up pressure after about 15 mins
(temp is about 190) it starts blowing white smoke from burning prestone instead of gasoline. Question -
do Fords circulate coolant through the intake manifold like "The "C" word" engines do or not? Are we
talking leaky intake manifold gaskets or leaky head gaskets here?
Thanks,
Mark
coolant leaks
- FreakysFords
Re: coolant leaks
To an extent, yes, they do. At least in that the cross over is the front of the intake. Worth checking further, so wait for some more responses. Some good folks here.
Frank
Frank
Re: coolant leaks
yes it does sound like a bad intake or head gasket or maybe a cracked head. do you get bubbles in the radiator when the cap is off and its running when warmed up?
- whitesmoke
Re: coolant leaks
No radiator bubbles - what would that indicate if we did? I've seen a cavitating water pump cause bubbles but what else do you think would do that?fordman wrote:yes it does sound like a bad intake or head gasket or maybe a cracked head. do you get bubbles in the radiator when the cap is off and its running when warmed up?
- BobbyFord
Re: coolant leaks
Pull the plugs and see if any are steam cleaned (especially the plugs on the 4 corners, near the intake water jackets), this may indicate a compromised intake gasket pulling coolant into an intake port.
- Ranchero50
Re: coolant leaks
You can also use a compression tester and hook an air hose to it to pressurize the cylinder to see if the head gasket is blown. Is it bubbling while running or just blowing white smoke?
Re: coolant leaks
bubbles in the water mean it is getting compression gases in the water jackets.
- whitesmoke
Re: coolant leaks
Thanks for the info - plugs are okBobbyFord wrote:Pull the plugs and see if any are steam cleaned (especially the plugs on the 4 corners, near the intake water jackets), this may indicate a compromised intake gasket pulling coolant into an intake port.
- whitesmoke
Re: coolant leaks
Just blowing white smoke after temp and pressure up to snuff - plan to get Jesse a compression tester for his birthday in JuneRanchero50 wrote:You can also use a compression tester and hook an air hose to it to pressurize the cylinder to see if the head gasket is blown. Is it bubbling while running or just blowing white smoke?
along with a dwell/tach meter
