bracket
- maverickfe390
bracket
Hey I have a 1967 F-100 4X4 that im going too be putting back together and I got a 1972 F-100 that Im using for parts the 72 has factory A/C so Iam going too be putting that into my 67.There is a bracket that goes from the a/c compresser too the top of the exhaust manifold do I need too keep that bracket ? And is AMK parts company a good place too get bolts from I do want too get a body bolt kit?
Re: bracket
keep the brackets and LMCtruck.com is a good place for body bolts.
Re: bracket
If the compressor is laid down flat, you really don't need that support bracket, but if you have it sitting up on end, then you should use the bracket to keep vibrations down.
Re: bracket
- maverickfe390
Re: bracket
yes it does sit stright up.So I have too use the exhaust manifold would they work going from a 2wd too a 4wd? AMK has a Body botl kit that has almost 300 parts too it.
Re: bracket
This constant myth than 2wd and 4 wd trucks are different needs to stop they are barely different and that is the difference is below the engine.
- 71PA_Highboy
Re: bracket
AMK is a restoration company, the the bolt kits you get from them are concours correct.
They are usually more expensive, but you can be sure they are EXACT and correct, hence the difference in models.
Dragon, when you sell concours correct parts, those minor differences can really hurt your business when someone doesn't have the right parts.
I have been buying (off and on) from Max since ~91.
hth
hth
Got Ford?
2 EarlyBroncos (68,69)
2 Classic Mustangs (69,70)
1 94 Ranger, 2.3, 5spd
1 Lincoln Mark VIII
1 Lincoln Mark VIII
Re: bracket
4wd and 2wd engine difference are very much. it has to do mainly with the oil pan and dipstick. as well you have to block off the old dipstick tube hole. then there is the factory crossover pipe fo rthe exhaust. nothing else i can think of is different on top of the enigne. only year to year changes would be the passenger exhaust manifold and the carb and emissions stuff. but getting correct parts that are correct for your engine and body is a plus in my book. also i think the compressor for the factory air was on its side. depending on which compressor that was used i think.
Re: bracket
I could run a 4wd with 2 wd pan and dipstick and exhaust manifolds. But everyone here has the newbies wondering about the differences like what carb difference and other things is different. I just brought this up as a way to help stop the myth of severe differences.
- flyboy2610
Re: bracket
Have you given a thought as to how you will operate the AC? The factory controls are sliders, while the 67 has cables. Factory AC was not available in 67.
Red Green
you'd better be right.
Red Green
Re: bracket
good question about the a/c. i gave this a quick thought or two a few days ago. but i didnt have my 67 here so i couldnt go out and look at it.
- maverickfe390
Re: bracket
Well Im going too cut out the piece where the sliders go and install them in the 67.
Re: bracket
