360 Stock/Typical Push Rod Length
70F250CamperSpecial
Post by 70F250CamperSpecial »
70 F250 360
I have a couple of push rods to replace. What is the stock/typical length? NAPA shows the following lengths:
9.56
9.621
9.68
9.59 (from change level 11 - ????)
Thanks, Rob
Dragon
Re: 360 Stock/Typical Push Rod Length
Post by Dragon »
I think it is 9.62 so a over tall lifter can go down one but a low lifter can be adjusted up two. Go with an adjustable set of Push rods
OldRedFord
Post by OldRedFord »
An adjustable set of push rods?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Dragon
Post by Dragon »
http://www.summitracing.com/parts/CRO-70000-16/
Yep adjustable push-rods. You can use them for hydraulic or budget solid lifer conversions.
OldRedFord
Dragon wrote:http://www.summitracing.com/parts/CRO-70000-16/
Here I thought they were just for checking push rod length and valvetrain geometry. Did not know they made other kinds that are meant to be ran in a motor.l
Tim
Dragon
Post by Dragon »
Nope the fastest way to convert an FE or any stop shoulder lifter setup. The problem is for racing they add weight to the push rod so for 6500 rpm motors and up they are a bad choice. For 5000 rpm motors they are great. One way past the higher valve train weight is to use a stronger valve spring.
