way of topic diesel
way of topic diesel
any one know of a way to delete the fuel filter housing on a 99 7.3 power stroke engine using an aftermarket filter assembly or a good website with a write up on the subject lets just say it might be put in a bump 4x4
if its fixed break it again red white and ford blue the only up hill thats good is the one you are going down
- fireguywtc
Re: way of topic diesel
I have not really looked into deleting the stock filter myself but you could look into a fass fuel system or similar which I believe also has a good fuel filtering system in it. From there on I would not know what else would be involved in the delete.
I don't know of any sites for fuel filter systems but you can check out http://www.thedieselstop.com/ forums and see what they have to say over there. They would be more knowlegeble about those kind of motors.
Bill
2024 F350 CCSB, darkened bronze
- convincor
This kit was on my truck. It didn't eliminate the stock housing but you did take out the stock filter.
http://cgi.ebay.com/ebaymotors/ws/eBayI ... ESELX%3AIT
What are you wanting to do??
"Still Plays With Trucks"
bump or dent with 7.3 6spd divorced t case 4x4 3/4 ton or 1ton older truck that could pull a mountain and what ever else needs movin. I went diesel but still love the sound of gas engine dual exhaust over the choppy whistle a diesel makes but the turbo sound in the cab is okay. just want something different that will last a long time
- averagef250
Is there room for a 6 speed and divorced t-case? I mean, I've used the ZF 6 speeds from PSD's behind Cummins engines in older Fords and I went mated t-case as I couldn't see how I'd get a 2" long center driveshaft to work. The 6 speeds are BIG. The floorpan must be cut out or a big body lift added.
I think it would be cool if you really thought it out and got everything to fit good. The only way I'd do a 7.3 would be if I ran across an 8 cylinder p pump. If I had one I'd have no choice but find a 7.3 PSD, gut the funky fuel system and electronics off and adapt the P7100 to it. I think that'd make for a pretty cool setup in an old Ford or Binder. I just can't get past all the electronics needed to run a PSD.
