FE "Van" oil pan?
JGH
FE "Van" oil pan?
Post by JGH »
Hello all!
I am installing a M-II front end and was told I needed a FE Van oil pan for the motor to clear the crossmember. Does anyone know where one could be had or even what the darn thing may look like so I could go to the junk yard and try to find one?
thanks
JGH
Hawkrod
Re: FE "Van" oil pan?
Post by Hawkrod »
Yeah, you need to start cultivating new sources of information. There was never, EVER an FE in a Ford van from the factory. Whoever told you that is been smoking way too much. The only rear sump pans were on 4X4 trucks and they are pretty hard to find these days. You will need the pan, the pickup, a special main cap bolt that holds the pickup, the dipstick and tube and if you get lucky the plug that fills the original dipstick hole in the block (a blob of silicone will actually take care of that though!). Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Redcap
Post by Redcap »
What motor is in your truck?
Hawkrod
Post by Hawkrod »
Redcap wrote:What motor is in your truck?
An FE is a 352, 360, 390, 428 etc... and they all use the same pan. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Redcap
Post by Redcap »
Maybe I'll wake up completely before posting next time... :doh:
the dipstick oil plug block off plug is 3/8 and it would have been a special order around here. i had to get one from soemone on here. he got it at napa i think.
convincor
Post by convincor »
fordman wrote:the dipstick oil plug block off plug is 3/8 and it would have been a special order around here. i had to get one from soemone on here. he got it at napa i think.
and i still have a extra in my desk drawer. :thup:
"Still Plays With Trucks"
did you send me two of them? i can't remember now where i put it if you did.
SteveC
Post by SteveC »
im planning on using the oil pan from dads n600 dump truck its full sump since i dented my 4x4 pan all to heck and back when the engine lift tipped over
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
won't the full sump do what the front sump would do and possible let the axle hit it? when goign over rough terrain.
convincor
Post by convincor »
fordman wrote:did you send me two of them? i can't remember now where i put it if you did.
I think I kept the extra.
as for the pan, you can buy a rear sump new.
http://www.summitracing.com/parts/MIL-30550/
BobbyFord
Post by BobbyFord »
4WD FE rear sump oil pan:
Ebay item # 300407855403
Ebay item # 200452540659
JGH
Post by JGH »
Thanks guys for clearing this up and helping me find a pan and whatever else is needed.
You are all awesome!
