Towing Capacity
Towing Capacity
Hey does anyone know what the towing capacity of a 70 F250 Camper Special is with a 390FE. I am thinking of buying a 24 foot travel trailer.
Re: Towing Capacity
Try this link, page 20.
http://www.fordification.com/library/ma ... temId=2048
- hotrodfeguy
Re: Towing Capacity
I know two bit on here has pulled over 10K with his 72
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
- eggman918
Re: Towing Capacity
Over 5.5K the Beast is unhappy
Steve
Re: Towing Capacity
64squire wrote:Try this link, page 22.
Thanks that answers my question the GVW of my truck is 7400lbs take 75% of that and I am sitting at 5550lbs.
- averagef250
Re: Towing Capacity
Myself, I find my '70 F-250 gets grumpy pulling more than 35,000 GCVW up more than 7% grade. Under 35,000 it behaves well as long as I have enough brake on the downgrades.
You need tires, brakes gears and common sense. You can safely move 80K with 20HP if you need to. My personal thought is if you need to ask a question along these lines you shouldn't be towing anything. Towing weight can be life and death in the wrong hands.
Re: Towing Capacity
I pulled my F350 with my F250 up a pass with no real hassles. I pulled my 10,000 pound boom truck up the same pass with my 360 in my F350 and had no problems.
Re: Towing Capacity
Yes my friend,Im not even going to go into this one,its like what he just said,averagef250 wrote:Myself, I find my '70 F-250 gets grumpy pulling more than 35,000 GCVW up more than 7% grade. Under 35,000 it behaves well as long as I have enough brake on the downgrades.
94 Ford F-150 super cab
Re: Towing Capacity
My father in law had a 53 m38A1 Jeep he put a 289 Special in. When they were moving his 14x70 mobile home onto his land they got stuck. He pulled the tractor and trailer out of the mud and back onto the road with the Jeep. I agree with the above. Trailer brakes set right and enough gear and traction and you can pull anything. You just had to watch what you are doing and use a lot of common sense.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- Redcap
Re: Towing Capacity
My truck regularly pulls 25k lbs worth of tractor on a big three-axle trailer. Even with the fairly tired old 352, it doesn't struggle. You just need to know how to tow.
