302 heads
towtruckerfour
302 heads
Post by towtruckerfour »
My wifes 70 F100 has a cracked driver's head. I picked up another head from a wrecking yard out of a 72 I think but not positive. I didn't look while I was there but I got home and noticed the spark plug size in the new head is smaller than what I have now. The head says 302 on it. Did they change the spark plug sizes each year or something? I'm going to look at the heads I have in the truck now and see what they have stamped on them. Worst case, I have to go get the other side so they match I guess. I don't really want to run two different plugs. Thanks for any help.
Troy
Dragon
Re: 302 heads
Post by Dragon »
You have a 351 Windsor head if I remember right and the head bolt holes are bigger by 1/16th of an inch. 302 guys ought to pop in here and give you more insight or tell me I am wrong.
basketcase0302
Re: 302 heads
Post by basketcase0302 »
I'm a "shadetree" for sure / no expert here. :lol: But I'd say yes, sometime around there (I thought it was 73 or 74) the head changed. Thank our government for that and a lot of other things done to our trucks. I've never heard of anyone running different heads, I imagine having different compression on each side of an engine would be pretty destructive?
I'd go get the other head for sure. :2cents:
towtruckerfour
Re: 302 heads
I was thinking since it was off another year, maybe that was the difference. I let you guys know what I find on the motor in the truck. To my knowledge it is a remanufactured 302 longblock when I bought it years ago. All else fails, I go get the passenger head to match. I'm always up for going to the junkyard to see what I can find.
Troy
convincor
Re: 302 heads
Post by convincor »
77 was the year they changed to the small plug which would be like a D7## casting
You want something older like D3, D4, or ever back to C8, C9 as the fisrt 2 digits in the casting #
"Still Plays With Trucks"
FreakysFords
Re: 302 heads
Post by FreakysFords »
Too bad yur too far, I'd give you a 70 302
towtruckerfour
Re: 302 heads
The new head has a D5OE and 302 stamped on the cylinder side. As long as it will work on the 302 I have I guess it should be ok. I don't think they will let me return it. I haven't looked at the one on the motor yet. Thanks Freakyfords for the offer. If this head doesn't work maybe we can work something out.
Troy
Hawkrod
Re: 302 heads
Post by Hawkrod »
The new head is a 1975 design (although the year of design does not mean that is the year of the engine, it could have been a later than 75 engine). It is not true that your old head is a 351 head, the other guys were right, you just got a later head. In 70 a 302 and a 351W used the same size spark plugs. It was a year dependant issue not an engine size issue. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
towtruckerfour
Re: 302 heads
Thanks guys for the answers. I am just wondering if I use the new heads once I get the other one, will I have any problems or will they work ok? I don't want to redo them again.
Troy
Re: 302 heads
sounds liek if you get a matching pair of heads they will work and use the same spark plug. the only thing i can think of is it may be a pair of emission heads. so they wont be quite as good for hotrodding and so forth.
Doug F
Re: 302 heads
Post by Doug F »
You got dupped by the motor in the donor car having been replaced sometime. :doh:
Just go get the other one and you are fine.
Doug F
FALLOUT Grafix
Denver, CO
1967 F100 4wd 4spd
http://www.pinheadlounge.com/Pinecone
https://www.facebook.com/PineconeDesign
towtruckerfour
Re: 302 heads
Thanks for the help guys. I went back and got the other head. The truck was a 72 with a 75 motor in it I guess. After pulling the bad head off and comparing them, I couldn't see any differences except spark plug size. Now I have to pull the other head and put the motor all back together again.
Troy
