oil pan
89ford
oil pan
Post by 89ford »
hey can i use an oil pan out of an 1989 f150 302 for my 68?
Darek
BobbyFord
Re: oil pan
Post by BobbyFord »
Si, if it is the same sump location.
89ford
Re: oil pan
Post by 89ford »
well thats just it I don't know where the sump is on a 302 for that year span
Darek
BobbyFord
Re: oil pan
Post by BobbyFord »
If the 89 has a front sump and yours is a front sump then it will work. Which ever you go with it's always a good idea to measure where the pick-up screen is in relation to the bottom of the pan.
89ford
Re: oil pan
Post by 89ford »
I know where it is on my oil pan that is on the engine an 89 has a rear sump pan and I dont know where the sump is front or rear for the 68-72s?
Darek
BobbyFord
Re: oil pan
Post by BobbyFord »
68-72 is a front sump pan.
89ford
Re: oil pan
Post by 89ford »
I'm not sure but I figured they could interchange since there both 2wd half tons?
Darek
Re: oil pan
you could try swapping over everything and seeign if it would work. the major thing would be if the oil pump or only the pickup tube would swap over with the pan.
BobbyFord
Re: oil pan
Post by BobbyFord »
89ford wrote:I'm not sure but I figured they could interchange since there both 2wd half tons?
Like fordman said, the rear sump pan uses a rear sump oil pick up, the front sump uses a front sump pick up. The oil pumps may also be different. Some engines the oil pump is the same and just the pick up must be changed, other engines use an entirely different pump and pick up. You will have to research your 302 oil pumps for front and rear sump applications.
89ford
Re: oil pan
Post by 89ford »
I have the pan and pump in it what I am trying to figure out is if it will clear the crossmember under the engine in the truck
Darek
Re: oil pan
i bet it will. since its a rear sump pan it should fit with no problems.except exhaust crossover pipes.
JMcTurnan
Re: oil pan
Post by JMcTurnan »
I have a rear sump 302 if your interested, you can use any pan, but get the screen for it.
89ford
Re: oil pan
Post by 89ford »
ok guys thats what I needed thanks
Darek
