Funny my key is never in the ignition position except when it is running and then the choke needs to be hooked up.ToughOldFord wrote:The problem with using a keyed hot is the choke is going to warm up whenever the key is on whether the engine is running or not. The stator terminal is perfect for choke use since it is the only supply that will be hot only when the engine is running.
choke tubing to carb
Re: choke tubing to carb
