Of all the luck....Some people seem to think they are FUNNY!
LANCE65
Post by LANCE65 »
Last week I had taken the '69 I had for sale up to a friends house so I could clean up my back yard.Well then we got SNOW! COOL :woohoo: I didn't think nothing about the truck....UNTIL I get a call to come check it out. A freeze plug popped out AND there is water in the oil! :doh: So I am guessing a cracked block? :x :cry: ( I had never checked to see if there was any anti0freeze in it!) So, my plans of selling it (sorry Steve) have changed. I have a good running '77 F250 Ranger XLT that the body is not the greatest,but has a 460/C6 and all the mounts,front sway bar,rear sway bar,etc...that I may just swap over to the '69 and look for another bed.......any suggestions? Thanks
Oh and btw, I will have some 390 parts for sale.
-Lance
2015 Camaro-2001 GMC Safari-1984 F250 6.9/T19 2wd-1974 Dodge D100 short fleetside~ 72 wife ~ late model kids, a Chocolate Lab named Coco and a white rabbit named Marshmallow...now I need a ferret named Graham and I will have S'mroes!!!..lol :D
ToughOldFord
Re: Of all the luck
Post by ToughOldFord »
See? I told you snow is Evil!
BTW, check your antifreeze. :wink:
Re: Of all the luck
find another engine. or do a swap with that 460
72Highboy
Re: Of all the luck
Post by 72Highboy »
Just curious I was wondering how that happens I saw another post like that and was just wondering what happens. :hmm:
LANCE65 hope its nothing major ill keep my fingers crossed. :pray:
Joshua
aka Young Gun 8) :drive:
FE - Famous Engine
U.S. Army Veteran/11B
LANCE65
Re: Of all the luck
Post by LANCE65 »
It didn't have any anit-freeze and the water froze and pushed the freeze plug out. Now how the water got in there, I am not sure yet.
JMcTurnan
Re: Of all the luck
Post by JMcTurnan »
Thanks for reminding me to check my oil after I just put a cam kit in. I havent checked to see if intake is leaking.
OldRedFord
Re: Of all the luck
Post by OldRedFord »
Ouch. could be bad.
Ill throw out my vote for the 460 swap.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
ximy
Re: Of all the luck
Post by ximy »
I think you should replace the freeze plug and fluids and start her up
1967 f250 428
ToughOldFord
Re: Of all the luck
If there's water in the oil then the block is more than likely cracked. A blown freeze plug isn't going to cause internal leakage.
badboyzkustumz
Re: Of all the luck
Post by badboyzkustumz »
72Highboy wrote:Just curious I was wondering how that happens I saw another post like that and was just wondering what happens. :hmm:
coolant/water is flowing around the cylinders to cool them off. your engine block is constantly filled with coolant on the outside. IF you run straight water and no anti freeze your engine runs a very high risk of freezing over and causing a lot of damage. physics is a son of a bi$#@. warm water freezes faster than room temp water. water also expands exponentially when frozen. since your coolant and oil passages are side by side and you said you found oil in the water the block is toasted. damnit! i was suppose to pick it up tomorrow too! ah well.
67 F100 Stepside
302 5.0 V-8, C-4 Trans
Ford Certified Technician, UTI Graduate
JMcTurnan
Re: Of all the luck
Post by JMcTurnan »
Id put a new freeze plug and coolant in. You never know. Maybe it was just ironic. Water could be getting in oil, you have anti freeze in it right? if you didn't thats ur problem
ToughOldFord
Re: Of all the luck
Irony, the number one cause of water in oil.
Yes, you should run 'anti-freeze' year round, even if it doesn't freeze where you live. It's functions also a rust inhibitor for the cooling system.
cdeal28078
Re: Of all the luck
Post by cdeal28078 »
If you look on most gallon jugs it does say antifreeze/coolant.
We did an experiment in chemistry lab once when I was in school. Cold water freezes faster than warm or room temperature water. I think one of the TV shows showed that also. lol
IF the engine has not been turned over and water is showing in the oil afrter a hard freeze you can bet a cylinder wall has busted.
Time for a 460!
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
badboyzkustumz
Re: Of all the luck
Hot water freezes faster than cold water. :doh:
http://math.ucr.edu/home/baez/physics/G ... water.html
67 F100 Stepside
hazelnut
Re: Of all the luck
Post by hazelnut »
I use to be a plumber for about 10 years and most of the time when a pipe freezes and bust its 80% the hot water line.
