Torque Specifications
I'm ready to start puting back togeter my 302 engine. Can somebody help me to find one torque specifications sheet? I'll appreciate your help.
Re: Torque Specifications
Good afternoon McDays!
This is from the 1972 Ford Truck Manual page 21-21-31:
Blue Loc-tite can be used instead of oiling the threads on the larger bolts. Same torque value/
Thank you all for the help.
I still got questions. Now I think I loose one small hose from the thermostat housing. I'll buy one. But where should it be connected? From the thermostat housing to where? Thank you for helping me.
- eggman918
I always use Anti-seize on head and main cap bolts,they torque better and disassemble much easierDragon wrote:Blue Loc-tite can be used instead of oiling the threads on the larger bolts. Same torque value/
Steve
that little hose i think goes from the stat housing to the water pump. it is just a small curve of a hose. it isnt over 3 inches long i think. the hose is bent / molded to a 90 degree turn.
