noise when I hit the gas
was making some noise (like a clacking. now when i was drivin i heard it get louder , oh crap. sound like its on the drivers side. timing.?
Re: noise when I hit the gas
Sound like marbles in a tin can? A rattle? Might be spark knock
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
yeah i regapped and i think it went away. plus im low on oil .
Have not we had a bout 3 threads on this?
I seem to recall somebody saying something like:
I know I'm starting to sound like my father here, but if you want good advice you are going to need to start with a nice well thought out post explaining the nature of the problem, conditions under which it occurs and any additional descriptive information (a good description of what the noise sounds like in this case). When someone responds and asked a question for clarification, that clarification would be of benefit.
Simply continuing to ask similar questions in new threads is unlikely to gain anyone (you included) much insight into your problem.
Or something like that...Find a friend who believes in timing lights before you start cleaning pistons out of the oil pan...
Seriously, stop driving/running it NOW and figure out what is wrong with it.
You are going to blow the motor up if you haven't already!
A noise that gets louder with more throttle. Rod and Main bearing noise does that. Piston slap does that. Lifters do not do that They are just noisy and change in speed with rpm not power increases.
Gapping the plugs would not change knock unless the gap was so large that the plugs could not fire.
Low oil well I am the king when it comes to low oil noise. If the noise goes away when you add oil and it is not a tappet you need bearings, Bad. Also do the oil restrictor trick to the heads so more oil stays low.
As soon as my truck gets 2 qts down one tappet screams bloody tappity tappity tap. I have several leaking tappets that will get the axe when I change the cam, but first I need to get back to work.
saw dust will quite any noise. and clog up your oil pump too.
yeah dam GUY AT KRAGENS SAID THE PLUG WERE PRE-GAPPED. ******** lied to me .
They were pre gapped just not for your engine. They would have been gapped for the Duraspark. .040 to .045
almost sounds like a fast tick toc., oil didnt help i wonder if timing is off.
Timing that off would make the sound every firing cylinder.
Leaks at the exhaust manifold.
I second the exhaust leak...clacking soundDragon wrote:Timing that off would make the sound every firing cylinder.
2015 lifted Toyota tundra 4.6 4wd
2002 Toyota Sequoia 2wd 4.7 auto
1989 Ford F150
1979 Chevrolet C10 350/TH400 14 bolt "Big 10" (DD)
1972 F100 parts truck long bed
1971 F100 2WD LWB 302 aod 3.70 9inch PS pb
1966 International Scout 800
1954 GMC rat rod project Scout frame, inline 6, T90 4X4
1953 Chevrolet Tin Woody
1946 Hudson BigBoy Pickup-ratrod project
1989 Ford F150
make a video of it and post it on here. It could be determined more easily. I know this sounds stupid but it has happened before, check to see if the flexplate is tightened down all the way. A broken one can still work even if its broken off. More likely a flexplate bolt could be just a little loose and it is hitting the housing. Sometimes its the thing that you will never think of.
Justin
http://www.fordification.com/forum/view ... 22&t=47482
http://s976.photobucket.com/home/bb429power/allalbums go to both of the albums.
1967 Ford F100 longbed with a 466 500+hp/600+ft-lbs (mine)
1969 Mercury Cougar xr7 with a 351w (dads, I helped alot)
1970 Ford Maverick with a 302 (became our drag car)
1986 f150 5.0 (my DD)
"Many can argue, but it takes a real man to apologize."-Me
That is so rare as to be in the realm of 1 in 20 million.
Loose flexplate bolt makes noise for sure
1989 Ford F150
1989 Ford F150
Were the windshield wipers on? Because everytime I have mine on, i hear a ding, ding, ding. because theres something in the way that it keeps tapping. It could be many things, but this was a sound that most people would never think to be LOL.
