what can i use?
what can i use?
Hello I have bought a 75 ford f-100 and i was wondering what parts i could use to upgrade to my 68 i know i already have plans for using the front disc brakes but what else could i use or be interchangeable for upgrades?
Darek
Re: what can i use?
core support
enigne
transmission driveshaft combo.
the enitre front axles with disc brakes proportioning valve
enigne perches
rear transmission crossmember maybe the front one
exhaust system should work.
floors and front cab mounts.
ignition switch and complete lock set. you must swap the lever on back of the door locks to use them in a bump.
wiper switch. especially if it has delay wipers
windshield
window cranks
duraspark dist and box with wiring to wire it up.
tires and wheels
rear brake drums if they are the same size brakes.
rear axle can be used if it is modified to fit under your frame (moving the spring perches will do it)
the midship gastank as well as electric tank swapping valve
probabl ymore. but i cant think of it at the moment.
enigne
enigne perches
windshield
window cranks
tires and wheels
Re: what can i use?
i forgot power brakes and steering column to go along with the power steering.
Re: what can i use?
so if i was to put an hei distributor on my 302 do i have to use a computer with it?
Darek
- knightfire83
Re: what can i use?
Fords version is called Duraspark.so if i was to put an hei distributor on my 302 do i have to use a computer with it?
Yes, you would have to use the Duraspark ignition box with that distributor. There are aftermarket boxes such as MSD that can fire off that dizzy to. Definitely keep the distributor, ignition box, and as much wiring as you can. It is a good upgrade if you are currently running points, or you could e-bay it.
If equipped, save the A/C parts off that truck, I've seen a complete setup go for around $175 used. Or at a minimum save the compressor and brackets.
1970 Ford F250 4x4 ~ Sold.
Re: what can i use?
Will a 75 windshield fit a 68? I would have thought they were different but never thought about it or compared them.
clint
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
1986 Bronco 5.0 AOD
- knightfire83
Re: what can i use?
Yes, they are the same.
To confirm: LMC Truck lists the same windshield part numbers for both the 67-72 and 73-79 trucks.
49-9720-t clear
49-9722-t shaded
49-9724-t tinted
49-9720-t clear
49-9722-t shaded
49-9724-t tinted
Re: what can i use?
This is a parts truck with no engine or radiator but im gonna use a distributor off of ebay thats a gm style made to fit a 302 like im running im just trying to understand if im gonna have to use a computer with it heres the url http://cgi.ebay.com/ebaymotors/ws/eBayI ... EWAX%3AVRI
Darek
- knightfire83
Re: what can i use?
No, a GM HEI style dizzy only has 2 connectors. 1 for power, 1 for tach.
Copied from the auction:
FOR THOSE NOT FAMILIAR WITH USING THE GM STYLE HEI DISTRIBUTOR IN A FORD ENGINE. IT'S A VERY SIMPLE HOOKUP. THERE ARE TWO MALE SPADE TERMINALS IN THE CAP. ONE IS MARKED B AND THE OTHER IS MARKED T THE B TERMINAL IS TO GO TO A POWERED SOURCE THAT IS ACTIVE WHEN THE KEY IS IN THE ON POSITION, AND MUST ALSO SUPPLY POWER WHEN IN THE CRANKING POSITION. THE T TERMINAL IS FOR A TACH, IT'S THAT SIMPLE. ALL AUTO SUPPLY AND HARDWARE STORES HAVE SPADE TERMINAL KITS. THIS DIST. ONLY REQUIRES ONE WIRE TO BE UP AND RUNNING. USE AT LEAST A 10 GAUGE WIRE TO THE DIST. IF YOU HAVE AN OLD POINT STYLE FORD, DO NOT USE ANY OF THE OLD WIRING, AS THEY ARE TO SMALL, AND DELETE THE BALLAST RESISTOR FOR SURE.
This information that the seller posted is correct, use a relay or solder a 10 gauge wire directly to the Ign. terminal on our trucks ignition switch. Don't run power to the HEI thru the resistance wire on our point style ignitions.
That is a neat dizzy, I'll have to look if he's got one for a FE.
Re: what can i use?
becarefull with that dist they take up alot of room on a 302 had one on mine and had to change it out becaus of clearance issues with my new intake and air cleaner, went to a procmp ready-to-run dist of ebay and it worked great and did not have to use a box to run it it worked just like the stock except better it hooked up the same also, think i only gave $150 dollars for it plug wires and coil on ebay.
65 F100 swb 302 project
67 dodge coronet 440 also wife's car great mopar though
2005 dodge ram 3500
2008 dodge ram 1500 cc
2005 dodge ram 3500
- 69rangerf100
Re: what can i use?
i dont think i could ever bring myself to put a GM part on my ford. i am a true blue fan. if i ever had to drive a chebby or GM again i would drop in a ford motor right away
David
Dream as if you'll live forever, live as if you'll die today - James Dean
Daily Driver - 1998 Honda Accord
Wife's Ride - 2007 Ford Explorer Sport Trac
Project - My Dad's 1969 F100 Ranger 390 w/ 3spd manual coming soon PS, PB, A/C and alot of paint and body work - Miss you Dad
http://s936.photobucket.com/albums/ad208/69rangerf100/
Re: what can i use?
oh believe me i am a ford fan too i am 17 but ive got a ford emblem tattooed on my right arm no joke haha anyway ill have a high rise weiand intake with a edelbrock carb i think it should be able to clearance it well
Darek
- OldRedFord
Re: what can i use?
Why not just get a duraspark and be done? Not that expensive.
$50 for one at Oreilly's. Get a module at a junk yard, or post a want add in the wanted section.
Duraspark is better then a HEI anyway.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
- basketcase0302
Re: what can i use?
You can also use the 75's gas pedal assembly with the cable linkage, and the brake pedal assembly.
Re: what can i use?
I'm going to at least try and use one of these distributors for the price im sure i can get at least half the price I paid for it but I think it will be something neat to try since I am kind of new to this. I never have built an engine and this is my first ground up build for my 68 shortbed.
Darek
