390 truck piston cc?
- fomocoguy
Do any of you know the approximate volume of the dish and valve notches on a stock 390 truck piston? If my 300 project needs to be bored out enough I may use 390 pistons but I need to know the cc's of the dish so I can calculate compression ratio. Thanks!
Joe
1971 F100 flareside 8ft
2006 Dodge Ram 2500 cummins
2005 Ford Ranger
2005 Ford Ranger
- hotrodfeguy
Re: 390 truck piston cc?
Well, full dish is 9.5 CR, and the flat tops with just the eyebrows are 10.5 hope that answers what your after. The 390 truck pistons are 410 pistons and had lower end of 8.X CR I think off the top of my head the 72 390 was like 8.2 But dont hold me to it but its right around that.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
- HOWDY69
Well Summit says the 381NP has a recess 0.097 inches deep and 2.62 inches in diameter. So that would be about 0.52 of a cubic inch or 8.6 cc if my math is correct. I do not think this includes the eyebrows and each brand is different so YMMV.
http://www.summitracing.com/parts/STL-381NP30/
Mine were cc’ed in the hole which includes the volume above the ring and the depth below the deck but it seems like I got pretty close with the above estimate.
- fomocoguy
Thanks, but I'm not using them in an FE so I need to calculate it with my specific set up.hotrodfeguy wrote:Well, full dish is 9.5 CR, and the flat tops with just the eyebrows are 10.5 hope that answers what your after. The 390 truck pistons are 410 pistons and had lower end of 8.X CR I think off the top of my head the 72 390 was like 8.2 But dont hold me to it but its right around that.
Joe
2005 Ford Ranger
2005 Ford Ranger
- fomocoguy
That helps! I could probably just go with 9 cc and get a round about figure. Thanks!HOWDY69 wrote:Well Summit says the 381NP has a recess 0.097 inches deep and 2.62 inches in diameter. So that would be about 0.52 of a cubic inch or 8.6 cc if my math is correct. I do not think this includes the eyebrows and each brand is different so YMMV.
Joe
2005 Ford Ranger
2005 Ford Ranger
- convincor
Be sure and cc your heads. The C1 castings i used where spec'd to be 68-71 cc and actually are 78cc.
So with my build- block is 4.090 bore, 3.98"stroke crank, 381N pistons, calculates out to 9.37 to 1 compression.
418 cu.in.
418 cu.in.
"Still Plays With Trucks"
- fomocoguy
Wow, that's a big difference! My head is supposed to have 69cc chambers but I'll have to do that and see. How did you do it? I was thinking of putting a peice of plexiglass over the chamber with a hole drilled in the middle and just pouring oil out of a graduated cylinder to fill it up. Is there a more "correct" way or will that work fine?
Joe
2005 Ford Ranger
2005 Ford Ranger
There are tools to do it which I suppose one could argue might be "more correct", but the method that you propose will work. Obviously you will have to be very careful not to lose any of the fluid that you are pouring and give it time to "settle" to get accurate readings.
http://www.summitracing.com/search/Depa ... Rank%7cAsc
I'm not sure what most folks use, but it seems oil might be a bit "clingy" where the graduated cylinder and any funnel you might use are concerned. Automatic Transmission Fluid might be less so, and antifreeze much better.
The instructions from comp recommend "a 50/50 mix of water and alcohol with a few drops of dye or food coloring."
http://static.summitracing.com/global/i ... a-4974.pdf
- fomocoguy
Cool, thanks duck! I think I can pretty easily make one of these kits.
Joe
2005 Ford Ranger
2005 Ford Ranger
