Misfire except at idle
loglat
Post by loglat »
Redid my intake manifold and valve cover gaskets a while back, and while I was in there, I put in new plug wires and a distributor cap. Of course, I made careful note of the distributor position and which wire went to which plug. Now that I have it all back together, it idles fine, but if you give it any gas, it starts to sputter. I thought it might be the plugs, since everything else was new, but after replacing all of those, there was no real change.
The only thing I can think is maybe it's the plug wires. I have to admit, the store that I got them from had wires for the right engine, but it was made for I think a 72 or 74 model when mine is a 69. The parts book didn't go back in years that far, and I figured they were just wires, and with the same size engine and everything, what could go wrong? I may replace them, but I wanted to get a second opinion before I go spending money and time in the frigid air =)
Re: Misfire except at idle
i am going to guess vacuum leak. around the carb plate or intake gaskets. maybe who knows. i doubt it has jack to do with the wires.
loglat
Post by loglat »
Good point... I also replaced the PCV valve. The new one is a loose fit, but its hard for me to imagine that it would cause enough of a leak to cause that much misfiring.
Did you set the timing with a light?
if not it might not be right , it's hard to eye it up to the old position. :2cents:
Heathcliff68f100
Post by Heathcliff68f100 »
I would have to agree, set the timing with a light, and with the vacuum advanced disconnected and plugged
1989 dodge b250 van, 239 v6 blown a904 tranny RIP
1968 ford f100 lwb l6 240 c6 tranny
loglat
Post by loglat »
Wasn't so much eyeballing, we marked its position so it really SHOULD be good, but if that's the most logical explanation, maybe I'll try a timing light... We're on the same page though that there's a slim chance it has anything to do with the plug wires?
loglat wrote:anything to do with the plug wires?
Shouldn't be if they're new.
make sure the metal clip snaps on the plug , not just the rubber boot
knightfire83
Post by knightfire83 »
It's not your plug wires unless you damaged them while installing them (not likely.) The most common damage happens when pulling the wire off the plug, then the metal connector comes off. Another type of damage would be cracked, burnt, or crushed wires.
All spark plug wires are typically made out of the same material for a stock application at a parts store. The wire diameter changes along with how the wire is constructed inside for more performance related applications. Some car manufactures have different distributor side connections for a points type cap and a electronic ignition cap.
There is no substantial differences in a 1960's vs 1970's replacement spark plug wire set for a particular engine family. If you got them for a small block, they will fit a small block regardless of the engines age, same for other engine families. If your wire set had the proper connectors and length, your all set.
With that out of the way here is some more ideas....
- Did you gap your spark plugs before installing them?
- Check your firing order
- Is the vacuum advance hooked up to the right port on the carb? It should only have vacuum when you open the throttle up.
- Check for vacuum leaks as fordman indicated
- Clean and gap your points then...
- You really need to get a timing light and time this engine correctly
- Loose intake manifold bolts ?
- Adjust your choke as needed
:2cents:
1970 Ford F250 4x4 ~ Sold.
Dirty Offio
Post by Dirty Offio »
Just thought I would throw my 2 cents worth in. There is at least 1 way to screw up the firing order on the cap and get that result. (been there done that...what a pain in the a$$) It is usually 2 wires swapped...like 7 and 8 or 2 and 6. Actually I don't mind this problem as much as I despise having the distributor in 180 out! lol
Hope this helps.
Offio
When in doubt, hit the gas. It may not be the right answer, but at least it ends the suspense!!
The only substitute for Cubic Inches, is Cubic Money!
1967 F-100 swb "Varmit"
1968 F-250 4dr lwb "Beast"
1976 F-350 drw 460
1977 Club Wagon
1986 F-250 lwb
OldRedFord
Post by OldRedFord »
I would try a timing light to verify it is correct. Wont hurt to check.
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
