electronic ignition conversion
randyvines
Re: electronic ignition conversion
Post by randyvines »
I was aware that the 351 was not factory the data plate indicates that it was factory equipped with I6 240. One of my questions is how can i determine the year of the engine.
Redcap
Post by Redcap »
randyvines wrote:I was aware that the 351 was not factory the data plate indicates that it was factory equipped with I6 240. One of my questions is how can i determine the year of the engine.
No idea. I haven't had to deal with a Windsor yet, I'm more of a FE guy. Someone should be along soon to help you, though.
randyvines
That is what makes this site soooo great there is help lurking around every corner. Hope you are having a good Christmas Eve so far. In Waco snow flurries ribs off the smoker and cold beer on the evening menu.
sideoilerfe
Post by sideoilerfe »
I'm with redcap, Durospark distributor and either a Durospark or MSD 6A box.
shaggys_bump
Post by shaggys_bump »
randyvines wrote:Kind of a novice question, but...
when getting ready to order the system (I am looking at the Ignitor II) how do you tell the difference from single point, dual point mechanical advance or dual point vacuum advance? I really want to ensure I order the correct item. I do not know what the year of 351w in my 67 is.
If you want to know what year it is i think the casting number is on the pass side of the block, first two letters tell you year
first letter tells decade and following number is year of decade.
B=1950-59
C=1960-69
D=1970-79
and so on
For instance D4AE-6015-AA 4 is a 1974 block.
1970 F100 Ranger XLT SWB 302
2004 Nissan Murano
1998 Isuzu Amigo "v6 4x4 conversion comin soon"
randyvines
ya'll rock!!! thanks merry CHRISTmas! Santa is on the way I saw him earlier in a 67 BUMP with tons of BIG boy toys!!!!!
for numbers you can look on the original intake the heads where the spark plugs go in at or i have heard under the valve cover on the head between the springs. and on the block just above the starter.
basketcase0302
Post by basketcase0302 »
Randyvines,
A vacuum advance distributor will have a vacuum diaphram on the side of the distributor like this one:
http://s240.photobucket.com/albums/ff13 ... g&newest=1
The "mechanical advance" distributor will be missing the vacuum diaphram on the side of the distributor.
Merry Christmas!
Basketcase
michael69
Post by michael69 »
If you go with dura spark just make sure you get the distributor from a 351w because 302s won't work on the 351w if I remember right.
Michael69
'69 Ranger 'F-100 2WD SWB 351W C6 AUTO
1985 CJ 7 jeep w/35s
1967 SS Chevelle 502 4 speed
2003 Heritage softail w/110 cubic inch screamin eagle kit
Redcap
Post by Redcap »
michael69 wrote:If you go with dura spark just make sure you get the distributor from a 351w because 302s won't work on the 351w if I remember right.
Something get raised in the windsor series between 302 and 351w?
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
A 351W has a taller deck than a 302, which places the cylinder heads further apart and therefore prevents the use of any 302 intake manifold. However, it's not the reason you can't use a 351W distributor in a 302.
The distributor in the 351W is the same length as the 302 distributor. However, the 351W does use a larger diameter Oil Pump Drive Shaft. The larger drive shaft will require the larger diameter distributor shaft. The shaft diameter of the 302 distributor is ~.40”, while the 351W distributor is ~.53”. The 351W oil pump shaft input size is ~.31” and the 302 oil pump shaft input size is ~.22”.
A 351W distributor can be sourced from several stock Ford factory applications; mostly pickup trucks/vans.
michael69
Post by michael69 »
:yt: Thanks Keith I was trying to find the reason and post it but you beat me to it. THANKS :fr: :thup:
Michael69
cdeal28078
Post by cdeal28078 »
I thought the deck was higher also Keith? I thought that was why you can put a socket on the bottom of a 351w therm. housing and have to use a wrench on a 302? Just wondering.
clint
71 F100 SportCustom
1986 Bronco 5.0 AOD
