best mod for a stock 390
colorado71
Post by colorado71 »
Wanted some opinions on the best modification for a stock 390 4v it already has an electroinic distributor. and a carter 750 4v. everything else is stock. aluminum intake? hedders? :hmm:
1971ford
Re: best mod for a stock 390
Post by 1971ford »
There is a lot of debate whether or not stock exhaust manifolds or headers are better so i would just leave your manifolds for now.
You could swap over to a Edelbrock performer intake though, it is a dual plane aluminum intake that will save you a million pounds up front. I was told they are most simliar to our stock intakes, but of course they are a whole lot lighter.
-Ryan
70_F100
Post by 70_F100 »
First question:
Are you ABSOLUTELY SURE it's a 390?
Have you measured the stroke, or are you just going by what you were told by the PO?
Jarred Hodges
Post by Jarred Hodges »
I would go with headers. I believe that the factory manifolds were very restrictive
1971 F-100 swb 401 fe , edelbrock intake, cam, valve covers, longtube headers with twin 2.5 inch exhaust, aluminum wheels.
1965 Mustang 350 glide 7.45 at 90mph
1972 maverick 460 swap in progress
2002 z28 a few bolt ons
convincor
Post by convincor »
the factory type 4V intake will flow better than a Performer. If you going to bother with intake at least go to a Performer RPM.
Header won't do much for you at this point except make more noise so you think your going faster.
Best bang for buck in my opinion would be a cam change to something like a Comp 260H, XE262, or 268H. :2cents:
"Still Plays With Trucks"
colorado71
70_F100 wrote:First question:
yep, i know the last owner, unless the machine shop that built the engine b.s.'d him its a 390. the truck origionally came with a 360.
colorado71
Is there a certian year of head thats better than others?
dustman_stx
Post by dustman_stx »
convincor wrote:the factory type 4V intake will flow better than a Performer. If you going to bother with intake at least go to a Performer RPM.
I agree with the cam change, but IMHO you are wasting your time doing a lot of intake upgrades without doing exhaust upgrades, i.e. exhaust and headers. You have to have flow through and engine, meaning you have to look at it as a system. If you really want good performance, get it flowing in and out.
sideoilerfe
Post by sideoilerfe »
convincor wrote: Header won't do much for you at this point except make more noise so you think your going faster.
I agree with convincor on the exhaust. I've put headers on a 352 and a 390 that both ran great and nothing changed. I'd go with a cam change first.
hotrodfeguy
Post by hotrodfeguy »
I would prolly drop to a 600cfm size carb, then look for a performer intake, maybe step up to a RPM if you are going to make more porwer later. Survival motorsports has a nice truck grind for a cam. That would be my picks for a stock engine.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
Redcap
Post by Redcap »
Cam and intake.
Headers and dual exhaust if it is a "car" 390 4v.
The factory 4v intake is at least as good as a performer in every respect except weight.
If it has stock exhaust manifolds the outlets may be as small as 2".
If its a truck 390, then probably nothing is going to do much until you get the compression up...
sideoilerfe
:yt:
DuckRyder wrote:If it has stock exhaust manifolds the outlets may be as small as 2".
Most are 2 1/4" . I've had 5 and they've all been 2 1/4".
DuckRyder wrote:If its a truck 390, then probably nothing is going to do much until you get the compression up...
I agree.
