Found: Old school Holley carb
papabug71
Post by papabug71 »
I was at the inlaws today looking thru one of the numerous junk piles & came across a pile of old carbs. Mostly QuadraJet's & a couple of Autolite 2100's. But the one that got my attention was this one. Its a Holley 4bbl, single inlet. I bet its been sitting out in the weather for 20+ years. :cry: Im afraid all it is now is an old Holley paperweight.
It has a FoMoCo tag on it that reads: C3TE F A 3ED
It has a Ford # on the air horn that reads: C3TE-9510-F
& it also has a Holley PN that reads: 2151-1
Any of you guys that can decode the #'s please feel free to do so. All I can get is 63' truck, engine.
Matt
Mine since 5/7/'94
302 / 3 speed / 3:25's
Re: Found: Old school Holley carb
does the linkage move? throttle shafts? and upp butterfly? if they are froze up trash it. if they move pretty good you could rebuild it i guess.
papabug71
Post by papabug71 »
Yeah thay are froze up pretty good. The guys at pony carbs said if it will move, they can rebuild it. Im going to let it sit in a bucket of solvent for a couple of weeks & see what happens.
What motor did Ford put in a truck in 63' that required a carb this big ??
Matt
Mine since 5/7/'94
lsevenpj
Post by lsevenpj »
Hi. I came across one of these carbs a few years back. The one I found came off of a big Ford(F600?) truck. That big mechanism on the side is a governor assy. Can't remove it because it's made into the base plate.
papabug71
Post by papabug71 »
lsevenpj wrote:Hi. I came across one of these carbs a few years back. The one I found came off of a big Ford(F600?) truck. That big mechanism on the side is a governor assy. Can't remove it because it's made into the base plate.
That would explain alot of things. They have 4 or 5 old F-600's/750's running around, & they were all converted to propane years ago. :thup:
Matt
Mine since 5/7/'94
FORDification
Site & Forum Admin
Site & Forum Admin
Post by FORDification »
:lol: I entered the number into Google, and FORDification was the first result:
http://www.fordification.com/bumpwiki/i ... aster_List
1961-63 Ford Trk., 292 Eng.
Ranchero50
Post by Ranchero50 »
Yeah, it's a governed big truck carb. Not worth much by itself, but probably worth parting out. I have one down in the shed from somewhere.
papabug71
Post by papabug71 »
Cool beans. I knew it was an older carb at first glance with the old Holley lettering & all. Too bad its all locked up.
Matt
Mine since 5/7/'94
fmartin_gila1
Post by fmartin_gila1 »
Back in the day, that carb was on all our 534 CuIn equipped larger C Models we had in the fleet.
Fred
hotrodfeguy
Post by hotrodfeguy »
Is that a 600 CFM? I have one in my garage thats in good shape, just needs a rebuild.
1972 F-250 4X4 390
1999 F-350 7.3 PS 4X4
1996 Ford ranger 3.0
papabug71
Post by papabug71 »
Im not sure of the CFM on it. :hmm:
fmartin_gila1, I forgot all about the monster 534 Ford put in the big trucks. Alot of the old peanut trucks around here had that motor.
I wonder if you could change the base out with a non-governed base ?
I polished it up last night. Looks good. & it works great as a door stop !!
Matt
Mine since 5/7/'94
