Where is a good place to get engine mounts for a 460? I got the frame stands and the part that bolts to the block from either here or 460ford. But anywho, I would like to get new mounts. (the rubber part) Oreilly only shows having the right side available and advance and autozone a no go. (I used 1977 for the year)
There was a page in the old tech section that had info on the different mounts and what years the 460 engine stands would bolt right into our trucks. But I cant find it?
engine mounts
- OldRedFord
engine mounts
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
Re: engine mounts
up to 79 from a truck for everything. stay away from lincoln mounts. something about they wont fit right or something.
- iamthewreckingcrew
Re: engine mounts
Got mine at Carquest. They are identical side to side. I also told them for a 77 2wd. I already test fit them too.
68 F-100 Short Box 2wd
302/c4/3.50
81 F-100 Long Box 2wd
460/c6/3.00
92 F-150 Lariat 4wd
302/auto couldn't go wrong for $500
302/c4/3.50
460/c6/3.00
92 F-150 Lariat 4wd
Re: engine mounts
Good afternoon Tim!
Alternatively, you could look at the Autofab polyurethane mounts. They're advertised to fit Bumpsides and accomodate 460 motors.
They're $260.
http://www.autofab.com/motor_mounts.htm
I put the Autofab engine and transmission mounts on my truck and they seem fantastic. I haven't driven it yet with them installed, but the build quality seems wonderful!
They're $260.
