Flywheel
Fastbackin1970
Flywheel
Post by Fastbackin1970 »
I have a 302 V8 with a three speed manual transmission. What flywheel should I have?
1970 Ford Boss 302
1972 Ford F100
Old Fords are like fine wine, they just keep getting better with age.
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Flywheel
Post by FORDification »
Depends on the year of the engine. In '81 all 302s changed from the 28 oz. imbalance with a 157-tooth flywheel to 50 oz. imbalance with 164-teeth flywheel and a 34-oz damper.
Fastbackin1970
Re: Flywheel
How can I tell what year the engine is?
1970 Ford Boss 302
1972 Ford F100
FORDification
Site & Forum Admin
Site & Forum Admin
Re: Flywheel
I'd suggest finding the casting number and date code, located on the right side of the block above the starter.
The actual engine assembly date is stamped in the block deck just below the distributor.
Fastbackin1970
Re: Flywheel
If I can get the casting number today is there a way to look up the flywheel?
1970 Ford Boss 302
1972 Ford F100
BobbyFord
Re: Flywheel
Post by BobbyFord »
Fastbackin1970 wrote:If I can get the casting number today is there a way to look up the flywheel?
If you get the date code then you just need to order a flywheel for that particular date engine.
Fastbackin1970
Re: Flywheel
D80E-6015-E is the casting number above the starter.
1970 Ford Boss 302
1972 Ford F100
Fastbackin1970
Re: Flywheel
28 oz. imbalance with a 157-tooth flywheel is the flywheel I need?
1970 Ford Boss 302
1972 Ford F100
BobbyFord
Re: Flywheel
Post by BobbyFord »
You need a flywheel for a pre-81 302. Where is your existing flywheel?
Fastbackin1970
Re: Flywheel
Still in the truck. I suspect the PO used the same flywheel that was on the 240 6 cyc that was in there. Not sure if that was the correct flywheel or not.
1970 Ford Boss 302
1972 Ford F100
70_F100
Re: Flywheel
Post by 70_F100 »
Fastbackin1970 wrote:I have a 302 V8 with a three speed manual transmission. What flywheel should I have?
Why are you questioning the flywheel? :?
Do you have a vibration? Is the clutch slipping? :maybe:
More info on your situation or specific issue/problem would be helpful!! :thup:
BobbyFord
Re: Flywheel
Post by BobbyFord »
Fastbackin1970 wrote:Still in the truck. I suspect the PO used the same flywheel that was on the 240 6 cyc that was in there. Not sure if that was the correct flywheel or not.
Right now you are just guessing. Pull your flywheel, get the part number off of it and go from there.
Fastbackin1970
Re: Flywheel
Original 302 had a vibration. After that engine failed installed a O/H Jasper engine. Vibration was much better but still present. Took it to the shop last weak after the vibration got stronger. So far have found a leaking rear main seal, broken engine mount on the right side. I suspect the culprit is the flywheel because it's the only part that hasn't been changed. I'm guessing that the flywheel vibration is to blame for both the seal and the broken engine mount.
Unless oil on the flywheel/clutch can cause a vibration.
1970 Ford Boss 302
1972 Ford F100
Fastbackin1970
Re: Flywheel
28 oz. imbalance with a 157-tooth flywheel is what I need, anyone have one for sale?
1970 Ford Boss 302
1972 Ford F100
BobbyFord
Re: Flywheel
Post by BobbyFord »
If you want to tell for sure what flywheel you need, there is a number on the front throw of the crankshaft 2MA = 81 and earlier crank, 2MAE = 82 and later crankshaft. If your block has a one-piece rear main seal, it should have the later crank.
