Fe Block Identification
I picked up this 390 that was seized up for 50 bucks just for the rear sump oil pan several months ago. I used the pan to put a 390 in my 85 pickup so all went well there. Now that that project is done i'm looking at starting another one. I still have this 390 block and i was looking at it the other day and i noticed that it had ribs going up and down the outside of the block. The 390 i put in my truck doesn't have this and i've never seen this on any other blocks. Is this a special block or somethin. Any insight is greatly appreciated Thanks.
1969 ford f100 351w aod
1967 f250 4x4 351c m50d
Re: Fe Block Identification
the ribs denote that it is a factory service block or factory replacment block. it not speical. i have one of them its worth less than a regular block. hurray for me. im not rich im even poorer since it takes up space.
Later FE blocks had that.
- sideoilerfe
How late? My D3TE and D4TE blocks do not have that. I've been wondering about that myself as I have a block with those ribs and without date code castings.
Intresting, It was my understanding that they started around 71, are your D3 and D4 blocks cast at MCC or DIF?
Of course where FE castings are concerned, you just never know...
the ribbed block i have is DIF. that is all it says on it.
- sideoilerfe
I'm not sure. I no longer have the D4TE block but i still have the D3TE. It is in the truck.DuckRyder wrote:Intresting, It was my understanding that they started around 71, are your D3 and D4 blocks cast at MCC or DIF?
Then I am not sure. I know it has been said that MCC produced cleaner castings so perhaps they were deemed no longer needed for whatever purpose they were to serve. It has been a few years since I did much study on it but I do think that I have even heard of blocks that had them on one side and not the other.
They do not indicate any thing "special" about the block though I am sure of that.
Here is just one thread on it at FE Forum.
http://www.network54.com/Forum/74182/th ... d+Block---
I would go with Dave Shoe on this; he has done a lot of FE research.
- sideoilerfe
Interesting. My "ribbed" block is out of my '72 Camper Special so what Dave says makes sense to me.
