1 barrel carb problem
I have a 1967 f100 with a 300 and 1 barrel carb. It will not idle runs good down the road but blows black smoke and pours out to much fuel when starting and idling any help would be great.
- OldRedFord
Re: 1 barrel carb problem
I know nothing about large 1 barrel carbs on cars but I do not think they can be too different from their small engine kin.
Sounds like it is running quite rich. Messed with the ide and mixture screws any?
Tim
1972 F350 flatbed drw c6/390
1967 F600 project truck
I'll assume it's a carter YF... Most likely the pump inside is shot and leaking
gas down inside the middle of the carb. Also could be a stuck float needle.
Just a spec of dirt or crud can cause that.
You'll need a rebuild kit to fix it up if the valve diaphragm is shot.
1968 F-250 / 300 six / T-18
Dana 60 - 4.10 Limited Slip
i unstuck the float and also added an electronic ignition system no it runs great thanks for help
