My Block
19FORD67
My Block
Post by 19FORD67 »
Ok I measured the stroke on my motor, it's 3.50. Since my VIN plate says 352 it's probably safe to say I have a 352.?
Any other thoughts on this?
:fr:
'67 352 3spd 3.25 9" Custom Cab
'92 Mercury Cougar
http://www.fordification.com/galleries/ ... ?pos=-3222
BobbyFord
Re: My Block
Post by BobbyFord »
352 and 360 both have a 3 1/2" stroke.
Re: My Block
how greasy does the outside of the eninge look? does it look as if its ever been replaced? if it doesn't look like it then its probably a 352. one way to tell with out removing the head is to check the crank to see which crank it has init. the 352 has a square notch and a half moon shape. the 360 i think only has the half moon shape. the 390 only has the square notch i think it is.
SteveC
Re: My Block
Post by SteveC »
pretty safe to say yes
1967 f-100 4x4
1988 ford f150 xlt lariat
1961 VW Beetle (wifes car)
flyboy2610
Re: My Block
Post by flyboy2610 »
352 would be an original engine for 1967. Last year they were made.
Red Green
you'd better be right.
mkpj1
Re: My Block
Post by mkpj1 »
Crank is the same for 352 and 360. Bore is 4.00 on 352, 4.05 on 360.
Pretty much the same engine, I doubt you could tell a difference with a compression test. There is a casting number on the passenger side front just below the head. May be able to confirm by deciphering this number but I'm afraid it would be the same as a 360, C6ME
Ken
Greenville, SC
68 F100 LWB 390
67 LTD 390(4V T-bird Special)
74 Bronco 351W
"I sincerely believe... that banking establishments are more dangerous than standing armies, and that the principle of spending money to be paid by posterity under the name of funding is but swindling futurity on a large scale." --Thomas Jefferson to John Taylor, 1816. ME 15:23
mkpj1
Re: My Block
Post by mkpj1 »
What I meant to say is,..if it is not C6ME then it could possibly be a reman 360....???
At the end of the day it really doesn't matter. At this point i would personally want to have the original 352 :wink: .
Ken
Greenville, SC
68 F100 LWB 390
74 Bronco 351W
Re: My Block
how thick is the grease on the enigne and bellhousing. that would be a good idea of how long the engine has been in the truck. if it is super thick and looks like its never been cleaned off since the 60's then you have a better guess at it. ifit is pretty clean that means one of two things. it was kept clean or it has possibly been replaced.
Alvin in AZ
Re: My Block
Post by Alvin in AZ »
What about using the date code? :)
Compare it to the pickup's build date. :)
Alvin in AZ
mkpj1
Re: My Block
Post by mkpj1 »
Found another block casting number(date code) for your year. C7AE-6010 or as i said above C6ME-6010-A. If it's one of these numbers, I'd put money on it's original block. Still unknown if it's been bored some in a rebuild. Anything with C8 or C9 or D anything would be not original and probably a 360. C= the 60' and the following number is the year in that decade. D=the 70's. As D3TE-6010 would be a a 1973 finished 360 block. The TE stands for truck engine, ME-mercury engine, AE- Ford engine. 6010 stands for -Finished Block.
Good luck.
Ken
Greenville, SC
68 F100 LWB 390
74 Bronco 351W
19FORD67
Re: My Block
Post by 19FORD67 »
I think I got this number from the head, its a C8AE-H, my intake man. is C7TE8425F, so head is '68 and intake is '67, still cant be sure what it is though, lol
:fr:
'92 Mercury Cougar
Re: My Block
measure the stroke its the only way. it may have been rebuilt if it has 68 heads. are both heads 68's?
Alvin in AZ
Re: My Block
19FORD67 wrote: I think I got this number from the head, its a C8AE-H, my intake man.
Those aren't "date codes" those are part number and update codes. :/
The date codes are just 4 figures like 8A12 would mean Jan 12 '68 in your case.
All the date codes I've found on my pickup (bought it new in '75) are from mid/late
January, one from late December and the York A/C casting is from like ~6 months
earlier. It's the only part I've found so far that was stored any length of time and
I don't understand why.
My '75 F100 SC parts truck and my '75 F150 were both made in the same week.
So were all the parts I have date codes for.
The "build date codes" that are on the tags of things like carburetors and steering
gears and (used to be on) engines too, are only three figures long like the two tags
at the top from my two Ford9inch axles...
http://www.panix.com/~alvinj/file12/Ftags.jpg
"5AD" = '75 Jan 4th week
The part+update numbers on -both- my FE-to-T18 bell housings are C5TA-7505-8.
Neither one was made in '65, see it? ;)
Alvin in AZ
mkpj1
Re: My Block
Post by mkpj1 »
Yikes,...he measured the stroke already?
Alvin, casting numbers ARE date codes. C= the 1960's decade; D= the 1970's and so on. As he has figured out his heads are not original. No way. They were CASTED in 1968. Look it up. the H,..means they were changed 8 times from the original casting. We know from his post that he does not have any tags which on his engine would have been under the coil??
You are correct in the fact that would have the PRODUCTION code which would tell us when the engine was ASSEMBLED.
Much like your bell housing C5TA=casted in 1965(C5) for truck line(T) and considered part of the chassis(A). The production code only tells us when they actually put it together on your truck so hypothetically it could be put on any truck for 10 years prior. So,...if Mr. 67 would take a wire brush to the right upper front part of his block and get me that number,...? the fact that it's got a different head means nothing. That coded head is a popular casting number so the originals owner(s) could have just replaced a head. C
shoot, after 40 years,..who knows,...??? A funny thing about my SB bump,..the casting number was C7ME-A which is cataloged as a 428 block :woohoo:
This truck had been a special order from the VIN with sea foam green and air conditioning etc...so I couldn't wait to check the stroke,..no such luck,..360 :cry:
Ken
Greenville, SC
68 F100 LWB 390
74 Bronco 351W
bjde0b
Re: My Block
Post by bjde0b »
This was a good resource for reading date codes:
http://www.classicmustang.com/decoding_part_numbers.htm
