engine stalling
engine stalling
I have a 1967 ford f100 with an inline six and a 2 barrel carb. When driving it on a hot day for about 15 minutes it shuts off and will not restart for about 10 minutes. It never overheats or runs out of gas. It usually happens when it has less than a 1/2 a tank of gas. Any ideas would be great Thanks.
Re: engine stalling
vapor lock? bad coil? are a few of things i'd check.
Jim
'75 Ford Highboy 390 4spd
- dantheman71
Re: engine stalling
I think a timing adjustment might solve that too??
1972 Ford F-100
2002 Ford F-150
2002 Yamaha Raptor 660
Check out my NEW build thread: http://www.fordification.com/forum/view ... 93#p641993
2002 Ford F-150
Re: engine stalling
i agree those are the first two things to check out.montana_hiboy wrote:vapor lock? bad coil? are a few of things i'd check.
Re: engine stalling
how exactly do i prevent vapor lock and what causes it
Re: engine stalling
I would check coil and timing, mine did that alot and it came out to be timing. Which now I got a new engine woot.
Re: engine stalling
I'd be willing to bet you've got a non-vented gas cap.
The next time this happens, immediately try to remove the gas cap. If you hear a whoosh of air when you remove it, that's your problem. What's happening is that as fuel is used, it creates a vacuum inside the tank, which the vented cap is supposed to prevent. Once enough vacuum has built up, fuel can't be sucked out. Letting the truck set for a short while will slowly allow the vacuum to dissipate, which will allow it to start and run again for a short while.
Simply replace the non-vented cap with a vented one, and I'll bet your problem will disappear.
- rjewkes
Re: engine stalling
is there a difference between the woosh and air/pressure comming out? i have a vented and get fuel spray is that ok? never stall just not sure if that is healthy.
fuelly.com
fuelly.com
