Carburetor issues ????
I have a 67' f-250 w/ the original engine in it (352). It has the autolite carb. And it is really hard to start. And after it does start,it runs ***** and then dies after about 5 min. Any suggestions ? I am trying to sell it,and I would get a lot more if i could fix this issue
67' F250 w/ 352 restoration project
97' Aerostar 4X4
97' Aerostar 4X4
- convincor
Re: Carburetor issues ????
may be a weak coil
"Still Plays With Trucks"
Thats an idea
I'll try it
97' Aerostar 4X4
97' Aerostar 4X4
a hot coil could cause that. have you had the carb rebuilt? you could try that also. maybe the engine needs a tune up. so it won't idle right? how does it run going down the road? does the truck die when you put it into gear? do you hear a hissing noise when the truckis running. does the truck die when you press on the gas and that is the only time it dies?
If I can even get it started,it runs poorly,for about 4 or 5 min. Then it dies. Then I won't be able to start it at all for at least 5 or 6 hours. And ,then again, it will take me 5 min just to get it started.
97' Aerostar 4X4
97' Aerostar 4X4
- convincor
sounds like a coil.
pull a plug, reconnect the lead a turn it over. Is the spark orange/yellow?? or brite blue??
check again after it's been run and dies...
Does any one know of a test you can do to a coil? like a multimeter test to see if its weak?
97' Aerostar 4X4
97' Aerostar 4X4
- convincor
http://autorepair.about.com/od/troubles ... st-ohm.htm
http://autorepair.about.com/od/troubles ... manual.htm
http://www.international-auto.com/afla- ... n-coil.cfm
Thanks Guys. I think my coil is weak. Readings were all over the place
. And it looks like it is older than the truck
97' Aerostar 4X4
97' Aerostar 4X4
buckeye_balls7 wrote:Thanks Guys. I think my coil is weak. Readings were all over the place. And it looks like it is older than the truck
think im gonna do the same, dam coil... if this is it, that would suck, i rebuilt my carb for nothing.
