crank pulleys
crank pulleys
i have a 71 390 this enigne had factory air and power steering. the crank has three belt pulleys on it. isn't the front pulley suppose to come aprt from the back set of two pulleys? all three pulleys are the same size. i tried heating them thinking they were stuck but that didn't do anything. i had the whole thing up on the bench off of the engine. so its not bolted together.
- Hawkrod
Re: crank pulleys
No, it does not come apart. Original factory Ford pulleys are one single piece because they are welded together in the center, only aftermarket ones will come apart. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
59 Tbird 430
60 Lincoln
(2)62 Tbirds
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
