The much thinner metering plate must have the bowl gasket then a tin plate with holes punched in it and then a smaller gasket that fits the pattern of the tin plate and metering plate.
http://www.holley.com/data/TechService/ ... 20View.pdf
Upper right hand corner is a metering plate layout. Part number 151,152, 153 and 149 are required. The tin plate is not part of a kit. Block 153, thin gasket 152, Tin Plate 151 and Bowl gasket 149.
Holley carb problem
Re: Holley carb problem
- willowbilly3
FWIW, any parts not available over the counter, just contact Holley engineering and they will make you one. They made me a whole new basplate for a 390, cost about $65.
