new fe fuel pumps
new fe fuel pumps
those newer fe fuel pumps that have the band around the center of them where the bolts use to go. has anyone cut that bamd off to see how it was held together? or iiis that band some sort of no tamper device that they are starting to put on the fuel pumps so it only looks like it cant be rebuilt? im just curious on whats behind that band. i think its a no tamper device. does anyone know?
Hawkrod
Re: new fe fuel pumps
Post by Hawkrod »
The band is what holds it together. There is nothing else. If you cut the band off you will not be able to do anything with it. There are no holes for screws or anything else. You have to have the equipment to install a new band as well as a source for bands to rebuild these type of pumps. The band is simply crimped over on both sides with rollers to lock the two halves together. Hawkrod
39 Ford Dlx Cpe
59 Tbird 430
60 Lincoln
(2)62 Tbirds
(3)68 Cougar XR7-G's
69 Cougar 428CJ 4 speed
77 1/2 F250 4X4
86 SVO
76 F250 Crew Cab
67 F250 Ranger
Dragon
Post by Dragon »
fordman wrote:those newer fe fuel pumps that have the band around the center of them where the bolts use to go. has anyone cut that bamd off to see how it was held together? or iiis that band some sort of no tamper device that they are starting to put on the fuel pumps so it only looks like it cant be rebuilt? im just curious on whats behind that band. i think its a no tamper device. does anyone know?
Where did you see this thing?
thanks hawkrod. i figured that was the way it was. dragon i have two of them here. one is new and the other is non working used. the used one will suck fuel but wont push fuel. so the pusher one way valve must have poped out of its place or its bad. i think i am going to cut the band off any way just for fun.
sideoilerfe
Post by sideoilerfe »
cdherman wrote:
FE pumps look to be in the $50 to$60 range. My kit for the 240 pump cost about $30.
FE pumps are $25. I bought 2 this year for my trucks.
cdherman
Post by cdherman »
I only checked one place (Advance Auto) and they were in the $45 to $60 range there. Were you able to get a pump with the canister filter for $25? Where?
65 f-100 SWB, 240 I6, T-18, now swapped to C4 with difficulty. Yeah, I know. Its a 67-72 site. But my frame and entire drive train are just like yours!!!!
willowbilly3
Post by willowbilly3 »
Last one I bought, they had superseded the truck one with the filter canister to the car one without.
I would hang onto the rebuildable kind if there are kits. There isn't much inside really, a diaphragm and a couple check valves.
sideoilerfe
Baxter auto parts. With the canister.
the newest one i have isprobably one or two years old. it has the canister. i didnt have to pay for it it had a lifetime warranty on it.
cdherman
Post by cdherman »
Anyhow, whether you can get one for $25 or $50 -- either way, it would be less hassle and clutter than hanging another filter canister somewhere on the frame rail.
Dragon
Post by Dragon »
I am going the other way. 2 electric fuel pumps and 2 filters before the tank switch valve and one before the carb.
sideoilerfe
cdherman wrote:Anyhow, whether you can get one for $25 or $50 -- either way, it would be less hassle and clutter than hanging another filter canister somewhere on the frame rail.
I don't think this is cluttered at all.
