AOD behind a 390?
AOD behind a 390?
Can any of the AOD (automatic) trannies live behind a 390 and still be a drop-in installation (slight modifications would be okay)?
Jeremy
1971 Ford F250 CS, SC, 2X4, 390, C6
- cobraF100
re: AOD behind a 390?
It wont be a "Drop In" but you can use a number of different Trans from Ford AOD's to Chevy AOD's with and Adaptor plate.Most of the Adaptor plate out there run around $750 and up.
This has been a topic here before if you want to use the Search to look it up.
Chris
Never Forget Our Soldiers
Re: AOD behind a 390?
I did this 2 yrs ago, unfortunately am having torque converter issues (not a reason not to do- stuff happens- even to C-6's) at present (Trans Overheats when in OD because TC is bad) but taking it to shop next week. Nothing like cruising 75mph at 2200rpm (with 3.55 r&p). You have to shorten driveshaft and relocate crossmember, and use a floor shifter (though there are now some cable linkages that may solve that issue).ttyR2 wrote:Can any of the AOD (automatic) trannies live behind a 390 and still be a drop-in installation (slight modifications would be okay)?
Heres some links:
where I got mine: http://www.lentechautomatics.com
some others
http://www.transmissionadapters.com/ford_fe.htm
http://www.fbperformance.com/NewSite/aboutus.asp
Good Luck -
Trevor Rush
- cobraF100
CACWBY,
Whats a Good time to call you tomorrow as I've found something out that may/should help out the over heating problem and still use a Good Stall.
Later,
Later,
Chris
